Cloud CPM F18a 80-Column
Re: Cloud CPM F18a 80-Column
No, it’s a hardware replacement for the video chip.
Thanks! This is fantastic on the emulator!
Now to find some affordable solution to run this on the Nabu Hardware.
Incorrect. The F18A is a VDP replacement implemented in FPGA. You remove the 9918A VDP and replace it with the F18A board.cavaughan wrote: Mon May 08, 2023 1:29 am I have no idea what an F18a is. Trying to figure that out, now...
Ok. It looks like it's an emulator. Correct?
Available here:
https://www.arcadeshopper.com/wp/store/ ... /539720609
there's also a home-brew hdmi version that was recently announced but you have to solder and assemble it yourself and it runs at 50% of the speed of the real version, if you just want 80col text it works fine for that
Here is the lower cost diy alternative: viewtopic.php?t=116
I'm getting the same blank blue screen, running MAME on a Linux host. How do I get this F18a emulator to work with my system?
did you read the first post?falken wrote: Wed May 10, 2023 4:51 am I'm getting the same blank blue screen, running MAME on a Linux host. How do I get this F18a emulator to work with my system?
It works fine on Windows, yes, but not on Linux. Do I have to be on Windows for this to work?
I asked but never got an answer.
Who created the F18a NABU MAME version? Have the changes been made available on github or some other usable form for compiling (non-Windows)?
Thanks.
Thanks.
I don't see every question. Here are the changes to use V9938 instead of the TMS9918ajefferystone wrote: Fri May 12, 2023 3:10 am I asked but never got an answer.
Thanks.
// remove this...
//TMS9918A(config, m_tms9928a, 10.738635_MHz_XTAL);
//m_tms9928a->set_screen(m_screen);
//m_tms9928a->set_vram_size(0x4000);
//m_tms9928a->int_callback().set(*this, FUNC(nabupc_state::vdp_int_w));
// add this...
V9938(config, m_v9938, 21.477272_MHz_XTAL);
m_v9938->set_screen_ntsc(m_screen);
m_v9938->set_vram_size(0x4000);
m_v9938->int_cb().set(*this, FUNC(nabupc_state::vdp_int_w));
There are additional changes required to compile f18a support for MAME.
I've attached a patch file against Brian's latest keyboard emulation update.
- Attachments
- nabupc-v9938.zip
- (1.16 KiB) Downloaded 556 times
