Added the ability to save the default NABU Channel so that it is selected when the Internet Adapter loads. For those using Cloud CPM more often than other NABU Channel options, this is a great way to have it load by default.
v2023.04.08.01
Re: v2023.04.08.00
Thanks DJ, I will definitely use this!
