How To Use Telnet
The Cloud CPM Telnet.com from A: User Area #1
How To Use Telnet
NABU RetroNET Telnet is a VT52 telnet client for the NABU to connect to other computers, such as BBSs. You will find the RetroNET telnet cient on the Cloud CP/M A: drive in User Area #1
Instructions
1) Select Cloud CP/M from the NABU Internet Adapter
2) Restart or turn on the NABU PC
3) The Cloud CPM BIOS Loader will display, download the BIOS and load it into the NABU high memory
*Note: If this is the first time you have loaded Cloud CP/M, or if the cloud A: or B: has been updated, they will be downloaded to ensure you have the latest content and updates.
4) When you are at the A:0> prompt, type USER 1 [enter]
5) At the A:1> prompt, type TELNET [Ip address] [enter]
