- This update has a checkbox in the Application settings. This new feature allows logging all communication between the NABU and PC to a file.
- Ability to log console to a file
- Also when Settings is saved, the listening server does not stop like it did before. This means if you changed the NABU connection port or settings, you'll have to manually start/stop the listeners with the buttons. This allows changing settings without having to reconnect each time.
v2023.04.15.01
Re: v2023.04.14.00
Nice to have a log file. The ops side of me is greatful.
Re: v2023.04.14.00
It’ll use a ton of space and cpu. Might cause performance issues on slower CPU’s. Remember it logs the entire communication.
Maybe you’re thinking logging the console messages? Because I can add that too.
Re: v2023.04.14.00
okay i updated this version to 2023.04.15.01 because it now has an option to log the console as well. Logging the communication fulltime is not advised.productiondave wrote: Sat Apr 15, 2023 8:49 am Nice to have a log file. The ops side of me is greatful.
Re: v2023.04.15.01
I was talking about the console log. I hadn't realized you were talking about a packet capture log.
Thanks for clarifying.
Soon someone will make a Wireshark plugin...
