How to use RNCMD
The RetroNET File Command Utility for Cloud CP/M that allows copying files between the NABU, PC, and User Areas.
How to use RNCMD
Also known as RetroNET Command, use this to Copy files between the Internet Adapter PC and the NABU Cloud CP/M drive. This tool also makes it easy to copy files between user areas in Cloud CP/M, which is usually daunting.
