USR-TCP232-306 to NABU Wiring
Instructions to create a NABU cable and get assistance with your cable. Even find out where to buy a pre-made cable.
c1ph3rpunk
Post by c1ph3rpunk »
Does this look correct for the wiring to go from the USR-TCP232-306 RS-422 Ethernet adapter to the NABU PC? Trying to document how it works as I go.
Pulled the NABU side pinout from here (page 7), adapter is documented here
The adapter
Wiring
tastypies
Re: USR-TCP232-306 to NABU Wiring
Post by tastypies »
Yes, that looks correct - and matches Table 3.1 on page 5 of the 'Unofficial Howto' guide viewtopic.php?t=67
tastypies
Post by tastypies »
...and remember to use twisted pair cable!
c1ph3rpunk
If I grab hookup wire, twist my legs around and drink twisted tea, does that count? ;-)
Related, I was looking at picking up some wire for these, looks like this would suffice:
https://www.belden.com/products/cable/f ... able/1419a
For now I’m just tearing up CAT5 to get the pairs. 422 can go decent distances when it’s STP from what I remember. Been a hot minute since I used it though.
c1ph3rpunk wrote: Mon Apr 24, 2023 5:30 pm 422 can go decent distances
Little bit, yeah.
